This procedure does not apply to 5320 Series and 5420 Series.
Ensure that you enable DvR on the node.
Perform this procedure to view all remote DvR routes on a Controller or a Leaf node.
The Controller node displays all the IP subnet routes configured for that DvR domain. A Leaf node displays all IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. It also displays the Host Routes (ARPs) learned from other DvR enabled nodes.
- Select DVR Remote.
- Select the Database tab.
- Optional: To filter the rows based on the specific criteria, select Filter.
Database Field Descriptions
Use the data in the following table to use the Database tab.
Name |
Description |
DestIpAddrType |
Specifies the address type of the IPv4 destination address of the DvR database entry. |
DestIpAddr |
Specifies the IPv4 destination address of the DvR database entry. |
DestMask |
Specifies the destination mask of the DvR database entry. |
L3Isid |
Specifies the Layer 3 I-SID of the DvR database entry. |
EcmpIndex |
Specifies the ECMP index for the DvR database entry. |
NextHop |
Specifies the MAC address of the next hop BEB, in the DvR database entry. |
L2Isid |
Specifies the Layer 2 I-SID of the DvR database entry. |
VrfId |
Specifies the VRF ID for the DvR database entry. |
OutgoingInterface |
Specifies the outgoing interface (port or MLT) of the DvR database entry. |
SpbCost |
Specifies the SPB cost of the DvR database entry. |
PrefixCost |
Specifies the prefix cost of the DvR database entry. |
NextHopName |
Specifies the host name of the next hop BEB, in the DvR database table entry. |
Age |
Specifies the uptime since creation of the DvR database table entry. |
